Bricscad crash on opening the settings dialog box
Support request submitted, ID 35851.
Bricscad V12.2.15-1 on Ubuntu 10.04 LTS - 3.0.0-23-generic-pae crash on opening the settings dialog box. This is the backtrace:
Program received signal SIGSEGV, Segmentation fault.
0xb5c9c287 in wxArrayString::Add(wxString const&, unsigned int) ()
from /opt/bricsys/bricscad/v12/libwx_baseu-2.8.so
(gdb) bt
#0 0xb5c9c287 in wxArrayString::Add(wxString const&, unsigned int) ()
#1 0xb65c22b9 in _loadSetCats(wxg::SettingsManager*) ()
from /opt/bricsys/bricscad/v12/libwxgui.so
#2 0xb66407b2 in wxg::SettingsManager::initialize() ()
#3 0xb6640828 in wxg::SettingsManager::get() ()
#4 0xb628d431 in wxg::DlgSettings::PopulateSetVars() ()
#5 0xb628da77 in wxg::DlgSettings::OnInitDialog(wxInitDialogEvent&) ()
#6 0xb5c4017f in wxAppConsole::HandleEvent(wxEvtHandler*, void (wxEvtHandler::*)(wxEvent&), wxEvent&) const ()
#7 0xb5cde609 in wxEvtHandler::ProcessEventIfMatches(wxEventTableEntryBase const&, wxEvtHandler*, wxEvent&) ()
#8 0xb5cdf6d4 in wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*) ()
#9 0xb5cdf7d3 in wxEvtHandler::ProcessEvent(wxEvent&) ()
#10 0xb5a78edf in wxWindowBase::InitDialog() ()
from /opt/bricsys/bricscad/v12/libwx_gtk2u_core-2.8.so
#11 0xb59c5b67 in wxDialog::Show(bool) ()
#12 0xb59c5de5 in wxDialog::ShowModal() ()
#13 0xb604b293 in wxg::ShowModal(wxDialog*) ()
#14 0xb604bd97 in wxg::dlgSettings(wxWindow*, OdString const&) ()
#15 0xb6e7be28 in cmd_settings() ()
from /opt/bricsys/bricscad/v12/libcommands.so
#16 0xb7680c03 in ca::InternalCommand::execute(OdEdCommandContext*) ()
from /opt/bricsys/bricscad/v12/libcadapp.so
#17 0xb52b5be0 in OdEdCommandStackImpl::executeCommand(OdEdCommand*, OdEdCommandContext*) () from /opt/bricsys/bricscad/v12/libTD_Root.so
#18 0xb7677cb3 in ca::CommandProcessor::execCommand(OdEdCommand*, bool&, bool)
() from /opt/bricsys/bricscad/v12/libcadapp.so
#19 0xb767b5db in ca::CommandProcessor::execStr(OdString&, bool, OdEdCommand*, bool, ca::Alias*) () from /opt/bricsys/bricscad/v12/libcadapp.so
#20 0xb767bea0 in ca::CommandProcessor::processString(OdString const&) ()
#21 0xb767c12c in ca::CommandProcessor::processNextCmdItem(int) ()
#22 0xb767c277 in ca::CommandProcessor::processIdle() ()
#23 0xb767c3c0 in ca::CommandProcessor::main() ()
#24 0xb767c4b7 in ca::CommandProcessor::start() ()
#25 0xb767c615 in ca::CommandProcessor::mainWorkFlowProc(void*) ()
#26 0xae063d39 in ?? () from /opt/bricsys/bricscad/v12/libpth.so.20
#27 0xaea8cc5b in makecontext () from /lib/tls/i686/cmov/libc.so.6
#28 0xaea7e0b1 in sigemptyset () from /lib/tls/i686/cmov/libc.so.6
#29 0x00000000 in ?? ()
(gdb) bt
Similar problem here this morning. Still finding 12.2.15 unstable.
(bricscad:1516): Gtk-WARNING **: Unable to locate theme engine in
module_path: "clearlooks",
p11-kit: couldn't load module: /usr/lib/pkcs11/gnome-keyring-pkcs11.so:
/usr/lib/pkcs11/gnome-keyring-pkcs11.so: cannot open shared object file: No
/such file or directory
Segmentation fault (core dumped)0 -
12.2.15 is unusable on Ubunti 12.04.Crashes of clicking the 'esnap' button... crashes of 'Settings'...0
Bricscad V12.2.16 Fedora 17 VM
When I print from the Print Preview screen Bricscad will crash with the output as below. Printing from the Print Settings Dialogue works ok, so after previewing a drawing, it may be necessary to go back to Settings, then print. -- YMMV.
(bricscad:2893): Gtk-WARNING **: Unable to locate theme engine in module_path: "clearlooks",
p11-kit: couldn't load module: /usr/lib/pkcs11/gnome-keyring-pkcs11.so: /usr/lib/pkcs11/gnome-keyring-pkcs11.so: cannot open shared object file: No such file or directory
WARNING: gnome-keyring:: couldn't connect to: /run/user/brm/keyring-EdVZoe/pkcs11: No such file or directory
[brm@localhost v12]$0 -
In Bricscad (Linux) 12.2.16 the settings dialog crash is fixed.
The crash was caused by an impartial removal of the Tool Palettes feature.
The Tool Palettes feature is suppressed on linux for the time being - it is not sufficiently stable yet.
By removing the Tool Palettes settings, all settings appearing below the Tool Palettes settings became invalid.0 -
Ok thanks, I was puzzling over the absence of Tool Palettes.
Offtopic
Do you have any news on implementing pdf underlay ? We use pdf files extensively.0
