Speed Test - Drawing 1000 and 10000 Solid3D Boxes using different Methods
I compared the speed of 4 different methods to create randomly solid3d primitives (entities),
using in this test a solid3D BOX object. Four different methods are used in a lisp file :
1. The command processor... using the command BOX in the command line
(vl-cmdf "_BOX" currentP1 currentP2)
2. The COM-Lisp interface (vl-load-com)
(vla-addbox Mspace (vlax-3d-point BoxCenterPT) (abs BoxL) (abs BoxW) (abs BoxH))
3. A Lispfunction programmed in C# .NET
(CreateSolidBOX currentP1 currentP2)
4. The native Lisp Function entmake
(entmake solBoxBCAD-entityList)
CP, COM, C#, LISP are used for 1, 2, 3, 4 in the table below respectively.
The results are as follows :
!! ALL NUMBERS are in seconds !!
No. of
Attempts CP COM C#.NET Lisp
Creating 1000 Solid3D Boxes in Bricscad 12.2.14-1 32bit
1st 2,09 1,08 1,22 1,51
2nd 2,15 1,06 1,15 1,48
3rd 2,23 1,08 1,15 1,5
4th 2,48 1,09 1,21 1,53
Creating 10000 Solid3D Boxes in Bricscad 12.2.14-1 32bit
1st 51,92 10,58 11,42 14,79
2nd 55,04 10,1 11,69 15,19
Creating 1000 Solid3D Boxes in "BIG-APPLE…" 2012 64bit
1st 7,94 2,4 2,6 3,9
2nd 7,79 2,48 2,6 3,96
Creating 10000 Solid3D Boxes in "BIG-APPLE…" 2012 64bit
1st 94,86 25,15 29,06 44,21
2nd 87,98 27,75 31,77 45,69
COM seems to be the winner ...!
It would be interesting if one could test BRX using a C++ function to create a BOX ???
The test was done on a Intel Core(TM)2 Duo CPU E8300 @ 2.83 GHz RAM 8,0 GB computer, running WIN7 64 bit.
I wanted to share the results with you !
In my tests (vla-add) works faster than (entmake) too.
Regards, Vaidas0 -
Interesting, but may be Apples and Oranges though.. There is a bit of overhead passing lisp arguments to .NET. as it has to be translated into a resbuf (BRX) then to a.NET ResultBuffer. The ResultBuffer class in itself is a monster, it has to thunk between managed and unmanaged memory and each argument also has to be translated be to a .NET TypedValue. I'm surprised it did that well : ) Go with strait C# and I bet it will perform much better.
[code]
using System;
using System.Diagnostics;
using Teigha.Runtime;
using Teigha.DatabaseServices;
using Bricscad.ApplicationServices;
using Bricscad.EditorInput;
using Teigha.Geometry;[assembly: CommandClass(typeof(ClassLibrary.Commands))]
namespace ClassLibrary
public class Commands
[CommandMethod("doit")]
static public void doit()
Stopwatch sw = Stopwatch.StartNew();
Database database = HostApplicationServices.WorkingDatabase;
using (Transaction action = database.TransactionManager.StartTransaction())
BlockTableRecord space =
action.GetObject(database.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
for (int i = 1; i < 1001; i++)
Solid3d solid = new Solid3d();
solid.CreateBox(i, i, i);
solid.SetDatabaseDefaults(database);
action.AddNewlyCreatedDBObject(solid, true);
space.AppendEntity(solid);
action.Commit();
sw.Stop();
Application.DocumentManager.MdiActiveDocument.
Editor.WriteMessage("\n{0}",sw.Elapsed.TotalMilliseconds);}
}[/code]
BTY my times are ... on a i5 laptop
121 milliseconds @ 1000
1184 milliseconds @ 10000
Dear Konstantin,
using ARX/BRX code you can expect (at least !) factor >= 2 compared to COM ...
besides, when Lisp engine has the "COM-ByPass" enabled for (vla-addXXX), then (vla-addbox) will also be faster by >= factor 2 :-)
That "COM-ByPass" is necessary for Linux, to have vlax(vla functions there, but it is tons of work, and already present, but for ~ 20% of all (vla-...) functions.
In other words, that "COM-ByPass" enabled (vla-addbox) will be at 90% of pure BRX performance and min. 2 times faster ...
Besides, if you place (vle-start-transaction) and (vle-end-transaction), you can even get (significant) more performance for such code constructions
(Daniel already published some amazing results, >= factor 50) :-)0 -
Hello Daniel and Torsten,
thank you for your suggestions and comments !
My test of course was meant as a means of testing different methods of solid3d creation
and their relative speed within the lisp scripting environment(Apples !) and not via straight C# or C++.
As a matter of fact to go straight ahead is mostly the fastest way to adopt(Oranges !).
Daniel :
I have used your code straight and embeded in a .NET Lispfunction, the results are obvious :
straight C# Lispfunction C#
111 milliseconds @ 1000 1006 milliseconds @ 10001464 milliseconds @ 10000 9828 milliseconds @ 10000
Torsten :
I am trying to understand what you mean...
When the Lisp engine has the "COM-ByPass" enabled (necessary for Linux) is faster..right ?
- How can the "COM-ByPass" be enabled or desabled ??
- How can I use the 2 vle- ... functions you suggest ? like in the following code :
[code]
(defun c:1001bx ()
(setq iter (fix (getreal "How many iterations :\n")))
; Set a Timer !
(if (wcmatch (getvar "ACADVER") "*Bricscad*")
(setq startTimer (getvar "millisecs"))
(repeat iter
(entmake solBoxBCAD)
(prompt (strcat "\r Population Complete - Elapsed time: "
(rtos (- (getvar "millisecs") startTimer))
(princ)
(setq solBoxBcad
(0 . "3DSOLID") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (100 . "AcDbModelerGeometry") (70 . 1) (1 . "700 0 1 0 ")
(1 . "@33 Open Design Alliance ACIS Builder @12 ACIS 22.0 NT @24 Wed Jul 18 10:59:32 2012 ")
(1 . "1 9.9999999999999995e-007 1e-010 ")
(1 . "body $-1 -1 $-1 $1 $-1 $-1 #") ................................etc.[/code]
- How do they relate to the "COM-ByPass" if at all ??
Could you please be more specific on how to make the lisp engine faster for (entmake list) ?
Thanks
Best Regards
Konstantin
Dear Konstantin,
that "COM-ByPass" is not related to (vle-start-transaction) / ((vle-end-transaction) ...
that COM-bypassing mechanism is already enabled in V12.2., but not yet for (vla-addBox) function.
So once this is also implemented for (vla-addBox), then there will be an significant performance improvement.
To get (entmake) faster, using start/end transaction, code is likely as you mentioned :
[code]
(if vle-start-transaction (vle-start-transaction))
(repeat iter
(if vle-end-transaction (vle-end-transaction))
[/code]
In generally, I would prefer (vla-addBox) instead of (entmake) ...
Many greetings !0 -
>>within the lisp scripting environment Ah yes, I think you will find C# 's (and BRX) relative performance to increase as the calls get chunkier, I.e. extending the arguments to include the layer, rotation etc. Fun stuff : )0
Dear Torsten,
thanks for the Informations !
I tried the 2 functions (vle-start-transaction) and (vle-end-transaction) for the COM and the C# Lispfunction.
Here are the results (in millisecs) :
No. of Boxes COM (vla-addbox...) C#.NET Lispfunction(createSolidBox...)
Using VLE- @ 1000 110 280
@ 10000 1076 2621
NOT using @ 1000 1029 1155
VLE- @ 10000 10389 11622
As it can be seen, the performance boost of using vle- is significant !!
Do all Lispers know this ? Is it documented ?
I have used this function
[code]
(defun 1001bx (iter vle-Flag AX-Flag / Mspace startTimer )
(setq Mspace (vla-get-modelspace
(vla-get-activedocument
(vlax-get-acad-object)))
; Use vle- for light speed !
(if vle-Flag (vle-start-transaction))
; Set a Timer !
(if AX-Flag
(repeat iter
(vla-addbox Mspace (vlax-3d-point (list 0.0 0.0 0.0)) (abs iter) (abs iter) (abs iter))
(repeat iter
(CreateSolidBOX (list 0.0 0.0 0.0) (list 1.0 1.0 1.0) nil) ;; a C# Lispfunction
; deactivate vle- light speed engine !
(if vle-Flag (vle-end-transaction))
(princ)
[/code]
Lisp Function Calls are as follows :
Using VLE- @ 1000 (1001bx 1000 T T ) (1001bx 1000 T nil )
@ 10000 (1001bx 10000 T T ) (1001bx 10000 T nil)
NOT using @ 1000 (1001bx 1000 nil T ) (1001bx 1000 nil nil )
VLE- @ 10000 (1001bx 10000 nil T ) (1001bx 10000 nil nil )
Thanks
Best Regards0 -
Dear Konstantin,
great results :-)
In fact, using a Transaction especially around Database operations can really boost performance - simply, because graphical updates are delayed, and reactors and other DB operations are "bundled" ... as mentioned, Daniel had tried this a while ago, with around factor 50 boost :-)
Nevertheless, using transactions is indeed a HighEnd feature, which should be used with care ...
Now imagine, when (vla-addBox) and similar are fully covered by "COM-ByPass", which gives at least factor 2 again ...
Currently I'm working on a "LISP Developer Support Package", which includes a comprehensive documentation for all the new Lisp Engine features introduced with V12.2. :
- VLE function set (+ emulation Lisp file for older Bcad + Acad + other systems; vle-extension.lsp is already installed in Bricscad folder, you might have a look at it)
- "COM-ByPass" technology (how it works)
- built-in automatic Lisp Optimiser
- built-in Lisp Profiler
- Lisp Benchmark system
- DEScoder.exe + its help
At this moment, it is ready for 50%, hope to get this package completed during August -> then it will be added to ApplicationsCatalogue.
Many greetings to all !0 -
Hello Torsten,
thanks for the Information...i am looking forward to work with the "LISP Developer Support Package" !
Regards0
