Chamfer
this may be a stupid question, but how do you specify an angle other than 45 degrees for a chamfer?
  • just to clarify, chamfering a solid not just lines.
  • Yeah, it appears the dmchamfer command can only do a 45 degree chamfer. There may be a better way, but you could get a chamfer at any angle by offsetting lines from the edge you want chamfered and using the slice command.
  • You can also use the chamfer command (as opposed to dmchamfer).  In that case, provide two different chamfer distances.
  • Tijs,
      When I use the chamfer command on a solid, it does work but there seems to be no way to predict which way the chamfer will be drawn. For example, I can specify distance 1 as .250 and distance 2 as .500, but I don't know which plane will take the .500 and which the other. Am I missing a step?
    Here's how it goes :
    : chamfer
    : (I pick an edge on a solid)
    : Enter surface selection option : Next / OK   (It seems not to matter which is chosen)
    : Chamfer distance on first entity : .250
    : Chamfer distance on second entity : .500
    : Select an edge or loop : (I select the same edge - redundantly)
    Then a chamfer is drawn. If I am lucky, it is done the way I need.
    I am using Bricscad Pro V12.1.23 .
  • Please ignore my previous post. For some reason it didn't post correctly.
    Tijs,
    - chamfer
    - (I pick an edge on a solid)
    - Enter surface selection option : Next / OK   (It seems not to matter which is chosen)
    - Chamfer distance on first entity : .250
    - Chamfer distance on second entity : .500
    - Select an edge or loop :  (I select the same edge, redundantly)
    Then a chamfer is drawn. If I am lucky it's drawn in the right way.
    I am using Bricscad Pro V12.1.23 for linux.
  • Well I guess I just don't know how to get anything posted correctly!
  • Hello Randy,
    I just tried myself.  Apparently the normal chamfer command does not have a proper flow and highlighting when used on a solid.
    The planes can be switched by using the "Next" option once when this message is displayed: "Enter surface selection option: Next/:".  However, no highlighting indicates which plane is selected as the first plane.
    The behaviour of chamfer will be re-evaluated.  Feel free to also post a support request about this.
    Regards
    Tijs
  • Tijs,
      Thanks for the reply. I think the best overall course would be to add the necessary prompts to the DMCHAMFER command to choose an angle and reference surface.
  • Thanks for all the feedback
