Erased objects stay on-screen until "regen"
In almost all my drawings when I erase objects they still appear on the screen until I do a "regen".
Is my graphics card (ATI Mobility Radeon HD 5850) causing the problem?
What can I do about it?
It sort of sounds like your REGENAUTO setting may be turned off...0
Unfortunately REGENAUTO (regenmode) is ON.It's even possible to zoom in/out on those objects.I can't select them, so this means they are really erased from the drawing."REDRAW" doesn't do anything, only a manually "REGEN" erases them from the screen.0
Also, everytime when this happens and I close BC without saving the file, BC returns an error "Bricscad is not responding...."When I exit and save the file -> No Error.I did a recovery and audit on these dwg's and there were no errors found.0
@ Tim:
In your first post you say: "In almost all my drawings ...". This suggests that the problem is related to certain drawings. I have found that AUDIT and RECOVER sometimes are unable to fix a problem with a dwg. Starting a new "clean" dwg and inserting, and exploding, a problem dwg in that new dwg has worked for me in those cases.0 -
REGENMODE should not have any effect on this. Please file a supportrequest with a sample drawing. It's possible that a problematic object in the drawing interferes with the redraw process.0
