Exporting to a DWF file
When exporting a Bricscad .dwg file to an Autodesk design web format file (DWF), (binary or ASCII), the DWF appears white on the screen of Autodesk Design Review viewer rather than the colors of the CAD drawing.  Is there a setting in Bricscad which would correct this?
Mike Ellis
  •  Hi Michael,
                 Compare to autocad2012 and autocad2013 you may see the difference in review viewer.if your dwg file in high version formate means it wont support in bricscad.
