Batch Plot Issue
I cannot properly run the Batch Plot VBA Utility. I get an immediate application error upon running the macro.
I am running Bricscad V12.1.19
Any thoughts on why the tool doesn't run?
Thanks,
Eric
  • No thoughts what is causing the problem with the macro, but...
    a V12 license is valid for all V12.x.x versions,
    so if you download the current V12.2.17 version,
    you will have the Publish dialog available to batch plot and save your print sets.
    Kind regards,
    Hans
