Exttools?
Does anybody know where I can download Exttools?
I can't seem to find it.
I'm (finally) upgrading to bcad v12.
Has it been discontinued?
If so, I haz a sad, they were excellent.
Right here: Exttools0
@Yaacov,
you might like to compare with the built in features of Bricscad V12. See http://blog.bricsys.com/2012/08/tip-working-with-blocks.html
Regards,Jason Bourhill
That link at the Swamp was where I first looked, but ExtTools.msi isn't there anymore, sorry.
I'm really looking forward to using the Drawing Explorer as a block manager, much neater, I think!
What I really wanted was a tool (in the menu) that came with ExtTool called
"Burst Block" which explodes blocks, converting attribs to texts with the attrib values.
I guess I can dig around the Swamp for something similar with a different name.
Thanks!0 -
I've posted it back on the swamp and also here
http://cadext.com/downloads/ExtTools.msi
Cheers : )
Thanks!0
Hello, I installed the Bricscad V13.1.15.1 and found the tools that Ext
unable to load it geht.Wird be a version for V13?0 -
I have posted a new build for you to try. You may have to uninstall older versions first.
Cheers : )
Daniel
Hello works without problems, thank you.0
Hello there, it is still a small problem with the V13.Beim call the entire height of Bricscad genutzt.siehe bild.V12 was ok.Bricscad V13.jpg0
Is the Exttools module for V12 still available?I have had it installed but have had to reinstall Bricscad recently and would like to reinstall Exttools. Installing the available version tells me I need to have V13.Thanks0
Hi Gary, Sorry for the late reply
the link for v12 is now http://www.cadext.com/downloads/ExtTools-v12.msi
Thanks Daniel.0
Hallo , wird es die Ext-Tools auch für Bricscad Pro V13.2.4-1 64 bit geben ?
besten dank im vorraus0 -
besten dank im vorrausHi,
I will make a build in the next day or two.
Cheers : )
Thank you very much0
