Resizing Viewports
I am having problems with viewports created in Paperspace. The contents move when I resize a viewport by dragging on the corners. How can I get the contents to not move when I resize the viewports.
Walter
  • I'm not sure what would cause that, but it's not normal behaviour.
  • @ Walter: Are you talking about a perspective viewport or a 2D viewport? If the viewport displays a perspective view dragging a corner will change the perspective. Doing the same with a 2D viewport does not change the view.
