Layout Setup
I have almost 200 Layouts. Every layout has an A3 border format as block refference (see attachement layout1)
I want to set-up all layouts on A3 format to match with my border.
How will be done?
Burlacu,
The answer really depends on how the drawing was originally constructed. Assuming:- Each layout already has an A3 border on it.
- The A3 border is a Block.
- Its the same A3 border block on each layout.
- Go into the drawing explorer _EXPBLOCKS
- Rename the current A3 block name to match the name of the one you want to replace it with.
- Use _INSERT and browse to where your replacement A3 border is located.
- Pick the OK button to insert
- When prompted as to whether you want to update the current block definition select Yes.
- Cancel out of the command.
If its more involved than this, then you would probably need to create a LISP/VBA routine to update your drawing.
Regards,Jason Bourhill
