Delete Layout
I want to delete 200 Layout's. I can't select all layouts with shift so......i delete manually?
Thank you!
I'm send SR (ID 23718 / 2010-04-10). And it was added it to the list of feature requests. ...But still not added to Bricscad releases... ;(
But you have right, actually it isn't possible yet.
But now I think, they can add this option to PageSetup in Drawing Explorer, ther is list of all layouts and there is multiselection possible, "simple" need ativate delete option...0 -
Hi Burlacu,
The CP_DELETELAYOUT command is part of our CADPower productivity tools for Bricscad, if you would like to use a third-party solution for the same.
See: http://www.4d-technologies.com/cadpower/manual/miscellaneous_tools.htm#DELETELAYOUTS
If you would like to create your own Lisp tool for the same purpose, these code snippets might help. One function deletes the specified layout while another will create a list of current layouts in the drawing.
You need to polish this off with a small wrapper and c: command.
[code]
;; | MI_GetPSLayoutsLst (new in V7)
;; | Function : Returns a list of paper space layout names
;; | Arguments: (none)
;; | Return : The list of layout names
;; | Updated : August 5, 2011
;; | e-mail : rakesh.rao@4d-technologies.com
;; | Web : www.4d-technologies.com
(defun MI_GetPSLayoutsLst ( / layout layoutName acadApp activeDoc layoutsCol layoutsLst )
(setq
acadApp (vlax-get-acad-object)
activeDoc (vla-get-activedocument acadApp)
layoutsCol (vla-get-layouts activeDoc)
layoutsLst '()
(vlax-for layout layoutsCol
(setq layoutName (vla-get-Name layout))
(if (/= (strcase layoutName) "MODEL")
(setq layoutsLst (cons layoutName layoutsLst))
(setq layoutsLst (reverse LayoutsLst))
;; | MI_DeleteLayout (new in V7)
;; | Function : Deletes a specifed paper-space layout
;; | Arguments: 'LayoutName'
(defun MI_DeleteLayout ( LayoutToDelete / layout layoutName acadApp activeDoc layoutsCol )
(setq
(if (= (strcase layoutName) (strcase LayoutToDelete))
(vla-delete layout)
[/code]
Regards
www.coordsys.com0 -
THANK YOU!0
