HATCH: how to add or delete loop of hatch boundary?
Hello,
is there any way to edit boudary of nonassociative hatch by set a new loop or delete some current one?
I mean the same effect, that provide autocad command "-HATCHEDIT / ADd boundaries" and "-HATCHEDIT/Remove boundaries".
I'm almost sure, that it is possible.
Thanks
Michal
Thanks
Michal
Hi Michal,In bricscad their is no command such as hatchedit. in future it may implement. better to try this command _BOUNDARY in bricscad.0
Since V12.1 it is possible to trim hatches. Not the same as HATCHEDIT, but trimming hatches can be very useful.0
For all, who have solved the same problem like me I have a solution:
we have developed an application "HATCHBOUNDARY" whitch subsitute HEDIT ACad command. You can download it from 'application store', 'general tools' section at Bricsys web page: www.bricsys.com/common/applications/application.jsp?app=6650
