rigth click: what to do that its always and Enter?
Hello,
comming from autocad i´m quite happy with bricscad v12, much better than te last version i tried (its as nice as the old autocad versions and much nicer as the slow monster tools autodesk is producing now). Anyway, the Option-Menu is a bit tricky, but still im getting better with it.
The last task quite annoying for me is the following: I want the right click to work as an "enter" always.
Im typing 10 fingers blind and usualy i type left handed the alias commands blind and right handed i use the mouse to do the "enter" job, never leaving the mouse right handed and the keyboard left handed, but one thing i cant get working:
If i select something and i do the right click, nothing happens apart a context menu opens (yes, right click is set as an enter in options).
For example i select a line, type copy and do a rigth click, a menu opens instead of copying these lines.
I have to type an enter instead of a right click this way round.
Other way round is working: if i type copy first, the right click is opening the command and i can select the lines within the command.
I want to have it working both ways via rigth click.
This problem occures to any comand, if i select something first.
For any command, i got no problems to select something, type the command and start with an enter.
Other way round, any command woks properly, if i type the command first i can open the command with a right click and can select within the command.
And: if im not in a command and i dont typed anyting, it should repeat the last command (done, i fixed that but it shouldnt be changed)
I hope someone is able to help me,
thx,
Joachim.
thx,
Joachim.
Hi Joachim,
Suggest you look at this post, which is related to the same settings.
https://forum.bricsys.com/discussion/18944
Regards,Jason Bourhill
thank you Jason,
switching off all of them is the solution.
and to know about these settings (i didnt found before) is great as well,
best regards,
Joachim.0
