Multiple Layout Select and Batch Printing?
I've looked around on the forums already with no luck -- I cannot select multiple layouts in a drawing (done in autoCAD by pressing ctrl or shift and confirmed it should be the same in bricscad).
In the same vein, is there a way to batch print? A search around the web led me to having to import a lisp routine for it, but it also seems batch printing is supposed to be built in now?
I should note I am currently using a trial version of Bricscad (trying to determine if the program is right for us) and I know the VBA features are not installed in the trial version... but I think this isn't a VBA thing?
Thanks!
Hi Tina, you might try the publish command and see if that works for you
Ha! Thank you; I hadn't even looked for that. Shows how much I've come to rely on how the version of AutoCAD I've been using for the last 7 years' behaviorWorks like a charm! Thank you again!How about the multiple sheet select thing? Another thing I'm used to doing is opening up a drawing that just needs a few layouts out of 20 or so and I'll multi-select/delete everything I don't need at once.0
