Create new block from existing one
I am looking for a way to quickly create a new block from an existing block (like the "make unique" function in SketchUp, for those familiar with it).
From a google search, it seems that Autocad may have a "save as" function in its block editor which would do this. But REFEDIT in Bcad does not seem to have anything like this.
Other than a lisp routine (which I may be able to piece together) is there a more direct way to accomplish this?
For a real quick solution, I would use COPYCLIP to "save" the block into memory, then rename the block definition in Bricscad, and then paste your previously copied block back into the drawing using PASTECLIP.0
That's brilliant. I was doubtful it would work, but it does.0
Here is a lisp routine I found online -- it seems to work fine in BCAD and does what I wanted.Thanks for the replies -- hope this might be useful to anyone else needing the same thing.;;; Creates a new block definition similar to the selected reference(defun c:cbq (/ old-ref new-name AcDoc Space Blocks old-name old-block new-blockobj new-ref)(vl-load-com)(while (not(and(setq old-ref (car (entsel "\nSelect the block to re-create: ")))(= "INSERT" (cdr (assoc 0 (entget old-ref))))))(princ "\nInvalid object."))(while(not(and(setqnew-name (getstring T "\nEnter the new block name: "))(/= new-name "")(null (tblsearch "BLOCK" new-name))))(princ "\nInvalid name."))(setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))Space (if (= (getvar "CVPORT") 1)(vla-get-PaperSpace AcDoc)(vla-get-ModelSpace AcDoc))Blocks (vla-get-Blocks acDoc)old-ref (vlax-ename->vla-object old-ref)old-name (if (vlax-property-available-p old-ref 'EffectiveName)(vla-get-EffectiveName old-ref)(vla-get-name old-ref))old-block (vla-item Blocks old-name)new-block (vla-add Blocks(vlax-3d-point '(0 0 0))new-name))(vlax-for o old-block(setq obj (cons o obj)))(vlax-invoke AcDoc 'CopyObjects obj new-block)(and (vlax-property-available-p old-block 'Units)(vla-put-Units new-block (vla-get-Units old-block)))(setq new-ref(vla-insertblockSpace(vlax-3d-point '(0 0 0))new-name(vla-get-XScaleFactor old-ref)(vla-get-YScaleFactor old-ref)(vla-get-ZScaleFactor old-ref)(vla-get-Rotation old-ref)))(vla-put-Normal new-ref (vla-get-Normal old-ref))(vla-put-InsertionPointnew-ref(vla-get-InsertionPoint old-ref))(if (= (vla-get-HasAttributes old-ref) :vlax-true)(progn(setq old-att (mapcar '(lambda (att) (cons (vla-get-TagString att) att))(vlax-invoke old-ref 'getAttributes))new-att (mapcar '(lambda (att) (cons (vla-get-TagString att) att))(vlax-invoke new-ref 'getAttributes)))(foreach att new-att(foreach prop (list'Alignment 'Backward 'Color 'FieldLength'Height 'InsertionPoint 'Invisible'Layer 'TextString 'Linetype 'LinetypeScale'Lineweight 'Material 'Normal 'ObliqueAngle'Rotation 'ScaleFactor 'StyleName 'TextString'Thickness 'TrueColor 'UpsideDown 'Visible)(if (vlax-property-available-p(cdr (assoc (car att) old-att))prop)(vlax-put (cdr att)prop(vlax-get (cdr (assoc (car att) old-att)) prop)))))))(vla-delete old-ref)(princ (strcat "The block \"" new-name "\" has been created."))(princ))[/code]0
