how to open an *.SV$ file ?
sometimes my program shuts down and all recent information disappears but is probably saved in the .SV$ file or *.BAK file. But HOW can I retrieve this saved information from these files? In Autocad it´s no problem but in Intellicad I can´t find out how to do it!Hans Fredholm
.SV$ and .BAK files are normal .DWG files, only the file extension is different. To open such drawing files you can either modify the extension to .DWG or type *.SV$ or *.BAK in the FILE OPEN field on the OPEN DRAWING dialog box and press the ENTER key. All .SV$ and .BAK files in the selected folder will then be listed, then choose the file you want to open.
