Copying a layout?
in Other
Greetings,
In ACAD you are able to "click and drag" a layout from one open drawing to another open drawing. I have tried to do the same thing in the drawing explorer in V12.2.8, however, I see that is not an option. Is there another way to accomplish this in BricsCAD?
Dear Shawn
Top copy a layout from one drawing to another do the following:
1. In the target drawing, right click on an existing layout tab, then choose 'From Template' in the context menu.
2. In the 'Select Template File' dialog, browse to the source drawing, then click the 'Open' button.
3. A dialog box displays listing the available layouts in the source drawing: select the layout(s) you want to import and click the OK button.0 -
Thank you Louis, that is most helpful.0
