movement of cursor
 I have a problem - Working in briscad - the cursor movement is not continuous,
 even though snap is off,  grid is off.
 What can be the reason for this?
 Thanks
  Rachel
  • mouse or mouse pad problems, or check mouse settings in control panel. Other wise your computer might be having trouble processing a large bricscad file you have open. Try upgrading your processor or installing some extra ram.
  • I have the same problem on several computers. The mouse cursor jumps. It's getting a bit better, when the panbuffer is off.
  •  What is "panbuffer" ?
  • I notice a problem if I have two or more viewports open in modelspace in a large, complex  file.
    If one of them is zoomed out all the way and another is focused in to a detail,
    the zoomed in viewport will be very jerky and difficult to snap.
    If I set all viewports at roughly the same zoom level, there is no problem.
    I think I'll open a support ticket. Bricsys has been very responsive.
