dxf* file problem
i receive a dxf* drawing from customer but come open it. Anyone know how to open using Bricscad?
I can't open or Recover it either. I think it's only R14, so it's not too new, but it has mlines - not sure if that's chronologically correct.
'Invalid group code'.
If you open the file with a text editor you will see is starts:A dxf file would look like: 0SECTION 2HEADER 9$ACADVER 1AC1014....This is not an Autocad/Bricscad dxf file.
Looks like the forum treats the html header as html code. You'll need to actually open the file in a text editor.0
It reads in ASCII in my Opera, first lines are exactly as Martin's.
There is an image contained in the file, I tried taking it out but didn't help.
Here is the after repair.0
And there are performed repairs
MTEXT group codes
Row: 4224
Group code: 72
Undetermined. Supplemented with: 1
Drawing direction:
1 = Left to right
3 = Top to bottom
5 = By style (the flow direction is inherited from the associated text style)
LINE group codes
Row: 5618
221.06865196 30
Only: 221.06865196
Row: 5619
30
Row: 5620
0.0
Row: 5621
11
Row: 5622
239.8845799817
.0 -
Bohuslav want to ask you how you know how to performed the repairs.0
I opened the file in AutoCAD. The write line number where the error is located.0
