DOSLib 9.0 available for Bricscad V13
You can download it here:
http://wiki.mcneel.com/developer/doslib
Our thanks to Robert McNeel & Associates for keeping DOSLib up-to-date on Bricscad !
Cheers,
Luc
Cheers,
Luc
Great, Thanks, McNeel (Dale Fugier) and all involved.
I have been a long-time user of dosLib. It would be nice to have the same on the Linux version of BricsCAD as well.
Regards
Rakesh
www.coordsys.com0 -
forgive my ignorance, but what does DosLib do?0
Hi Keith,
Reproduced from the doslib documentation:
Rakesh Rao
DOSLib, is a library of AutoLISP-callable functions that provides a variety of Windows operating system capabilities to AutoCAD. Written as an AutoCAD ObjectARX application, DOSLib extends AutoLISP to provide the following functions:- Drives: Check for drives, change between drives, and check available disk space.
- Paths: Manipulate path specifications.
- Folders: Create, rename, remove, select, and change folders. Return special operating system folders.
- Files: Copy, delete, move, rename, and select files; get directory listings, search and find multiple instances of files, and change file attributes.
- Print: Get and set default printers, and spool print files.
- Configuration: Manipulate Windows-style initialization (INI) files, and access the Windows Registry.
- Processes: Run internal OS commands or other programs.
- Interface: Get strings, integers, reals, and lists from the user. Display Windows message boxes, progress meters, and splash screens.
- Strings: Tokenize strings, extract characters, find characters, insert, remove, and replace characters, and trim characters.
- AutoCAD: Save all and close all open files. Preview drawings and list xrefs.
- System: Get system information, sort lists, change the system date and time, manipulate the keyboard, and play sounds.
http://rakeshrao.typepad.com0
