2D drawings from models
Dear Tim,
I have not the V13 but the V12 Platinum, never I used others similar programs... however the program works fine except:
1)_the line hidden (if the choise is selected) of the aligned edges of others objects, are reproduced one over other upon the same tract for every edge...
2)_the circle, although orthogonal aligned, are reproduced as semi-circle...
3)_the 2d dwg from a 3d model can be done from the view or other ucs but never could be reproduced from a perspective view...
I find it useful to make 2d views from objects with complicated position or model... then I need to erase and/or re-writiing new line or poliline upon the 2d obtained. I don't know if other programs work better but this is useful, surely!0
