-BOUNDARY command
I added some entities to the selection set ss, defined "inner" point refPt and called
acedCommand(RTSTR, _T("_-BOUNDARY"), RTSTR, _T("_A"), RTSTR, _T("_I"), RTSTR, _T("_Y"), RTSTR, _T("_B"), RTSTR, _T("_N"), RTPICKS, ss, RTSTR, _T(""), RTSTR, _T(""), RTPOINT, refPt, RTSTR, _T(""), RTNONE)
to create a boundary.
It works fine in AutoCAD but not in BricsCAD. Does anybody know what is wrong or provide me a solution?
  • Please try to enter exactly the same sequence of input (names, arguments) interactively ..
    so run it manually ...
    alternatively, set cmdecho=1 in your Lisp code, and then check the commandline output,
    usually there you will see where (and eventually why) -BOUNDARY fails ..
    but "manual" mode is safest for investigation ...
    Many greetings, Torsten Moses !
  • It looks like, there is a problem with . Maybe there is a different way of providing a selection set in BricsCAD?
    Thanks for the answer in advance.
  • It looks like, there is a problem with (..., RTPICKS, ss, ...). Maybe there is a different way of providing a selection set in BricsCAD?
  • Due to our best knowledge, there is no known problem with (..., RTPICKS, ss, RTSTR, _T(""), ...);
    have you tried to use that command sequence manually at the prompt ? You can use a Lisp selectionset
    to mimic the input;
    I would assume, that the input sequence with -BOUNDARY is slightly different compared to Acad ?
    Using the commandline manually will show if command prompt sequence is fine.
    You can also create a small sample dwg with entities you want to get the boundary for, and a little Lisp
    to test that command sequence - if that works in Acad but fails in Bricscad, then please send us a SupportRequest.
    Many greetings !
