Export PDF at 1:1
Is it possible to Export to PDF at exactly 100% of the original size?
I have set everything up so it should export correctly, but when I open the PDF it has created a border beyond my zoom extents and used this as my zoom extents size, therefore reducing the vectors within so my extents fit within this size.
I am using the Export to PDF as opposed to printing to PDF as I need the layers and all my arcs and circles as arcs and circles.
The reason I need this 100% of the original size is Artwork will be positioned to this file so it needs to be correct. The drawing will then be forwarded to a tool maker who will then import this into a CAD system that runs a Laser, hence the layers and arcs and circles needing to be arcs and circles.
Please don't advise me to export as a DWG or DXF as they won't be able to be opened by some of the Graphics software and if they do I can't guarantee they will import at the correct size or retain the layers, arcs etc.
If you need a screen grab of my settings or the original dwg & created pdf please let me know.
Many Thanks in advance,
David Waight
David Waight
You need to do two things:
1.
Set the correct scale in the page setup.
Right-click on the Model/Layout tab > Page Setup... > Double-click on the icon in front of the tab's page setup name.
2.
Uncheck the PDF zoom to extents mode.
File > Export Options...0 -
Roy,
Once again, you have come to my rescue!
Thanks very much, I would never have worked that out by myself.
Appreciate all the help you are giving me.
David Waight0 -
David, I don't know if there is a loss of accuracy when you export to PDF. Since you are working in the field of packaging it is worth checking this.0
Roy,
After using your excellent instructions I exported a PDF, opened it up in two different PDF editors and attached them back into Bricscad.
I also converted the PDF into a DXF file using Inkscape (the one on the right) and imported it back into Bricscad.
As you can see the results are pretty good, so I can definitely use this method for creating my PDF's.
Once again thanks for the information and the concern over the sizing.
Kind Regards,
David Waight0 -
Do you guys know why PDF drivers on Bricscad do not let you save pdf formats on custem paper size, the only output is pc3.0
@ David:
Your message is unclear. What divers are you referring to? And do you perhaps mean A3 instead of pc3?0 -
Oops: I meant @ Gary...0
