"from" command modifier induces crash
"from" command modifier induces crash:
"line" [Enter] "from" [Enter] Basepoint: Snap to Basepoint
Results in "Bricscad Application has encountered a problem and needs to close"
This occurs in any drawing on both Win XP Pro & Windows 7 Starter
Can anybody else confirm this?
(Yes, I submitted a support request)
Hi Robt,
Yes does it to me too with V13.1.8 on Win 7. Seems to only happen at the start of the command. In the case of _LINEo could draw a line segment first then use _FROM. This doesn't help with other commands, such as _CIRCLE.
Regards,Jason Bourhill
Hi Jason
Thanks for the confirmation.
I use the FROM command modifier a lot.
In the interim, I've uninstalled 13.1.8 and reverted back to 13.1.7 and all is well.
Hopefully a fix will be released soon.
Regards0 -
Received a rapid reply from support:
"Thanks for pointing this out.
We will add an automated test and apply a fix in the coming days.
We apologize for the inconvenience"0
