ellipse explode problem
how to explode ellipse that drawn by Bricscad? If for Autocad we save it to version R14 dxf it will be explode. Did the same to bricscad but it also cannot be explode. We need to explode the ellipse to do wirecut software.
Hi Eric,
Try ._SAVEAS, then select "AutoCAD Release R11/R12 Drawing" from the Save as type drop down list. This will convert any ellipses to polylines, which you can explode on re-opening.
You can also set the _PELLIPSE variable _ON to force BricsCAD to always draw ellipse as polylines. This of course will make them very difficult to edit.
Regards,Jason Bourhill
Ok !! THK Jason Bourhill0
