functionalities needed!
HI everybody!
Bricscad reaaaaaaaly rocks!
Now we have almost everything: sheet sets, publishing, exporting to pdf and dwf, layer filters....
Is it possible to have EVEN MORE than autocad? YES.
My suggestions: (bcad fans - please add your ideas!)
JM1: Drawing Explorer should have the "layouts" icon with the possibility to copy one or multiple selected between opened drawings
JM2: Drawing Explorer should have the possibility to copy page one or multiple selected setups between opened drawings
JM3: Drawing Explorer should have the possibility to copy one or multiple selected layer filters between opened drawings
JM4: Open file dialog box should have the left pane more customizable - possiblity to add your own locations, and reorder them as needed.
Regards!
Jacek
In addition to "P" (previous) and "L" (last) selection set options I want "N" (new).
That means that "N" will choose all the entities created at the last drawing or editing operation.
For example if I copy 10 circles, "P" will choose the ten original circles,
"L" will choose the last circle created, and "N" would choose all ten of the created circles.
As it is, I have to individually pick the new objects, or copy-in-place and then move "previous".0 -
"N" would be really helpful, especially now a group of entities pasted into a file are not "P" anymore. That's a major step backwards.0
Do you, BRICSCAD TEAM, plan the implementation of autolisp and/or visual lisp "environment" tools?0
... copy one or multiple selected layer filters between opened drawings.
If you are using v13 Pro/Platinum (Windows) this freeware was just updated to support Bricscad.0 -
I would like to see a built in duplicate entity remover, like the Overkill command that was once available for AutoCAD via the ExpressTools. I found the XQuickDraw command to be a huge time saver on the last project I was doing, but the duplicate lines did take a bit of time to clean up...Interestingly, a quick Google search lead to this, apparently Overkill has been included in AutoCAD as a default tool: http://ltunlimited.typepad.com/my_weblog/2011/03/no-longer-express-tools-overkill-ncopy.htmlThe ability to adjust the vertices in a solid - A solid stretch command - or an option for the way that the default stretch command handles solids. Currently stretching a solid is similar to using the move command on the solid. It could be a huge time saver to be able to stretch a solid, use a crossing selection to select the vertices to stretch and then move them as you see fit - you would be able to make some very funky objects in no time.And/or grip editable solids would be awesome too, if you wanted to take a cube and make it a bit taller, just grip edit it and drag the grips to resize.0
Scott try this0
The Overkill command is included in the free Express tools
http://www.bricsys.com/common/applications/application.jsp?app=589&apploc=1002
With Drawing Explorer you can now copy Layer States, Layer settings, Text Styles, Dim Styles, etc.. between open drawings.
http://blog.bricsys.com/2012/03/tip-bricscad-drawing-explorer.html
Tip here for importing layouts
http://blog.bricsys.com/2012/09/tip-importing-layouts.html
Regards,Jason Bourhill
I wish the program could draw helixes so I could make true threads and springs. I don't have any LISP programming experience/ None of the LISP programs I located and downloaded for drawing helixes would work right with 13.2.9.
I would also like a calibration routine like that found in Autocad, so I can get accurate 1:1 printouts in both the X and Y dimensions.. Doesn't anyone but me ever print out labels?
I want to be able to import and export IGES and STEP.
Sheet metal unfolding would be nice.
A decent editor for multi-line text and dimensions, which allows me to easily insert special characters like the symbols for counterbore, countersink, spotface, etc. would be nice. Maybe symbols for welds?0 -
I would like to have the multiline text command remember the last text size used rather than base it on whatever was used on Dtext. Maybe there is already a way to do this which I'm not aware of?0
