Floating point error at start up. Versions: 11-12-13
Good morning,
I use Chakra linux, arch derivate.
I used both V11 and 12 in the past without any problem. I bought then windows license and for a while abandoned the linux version.
In order to get it a try, I installed the V13beta but I get a a floating point error on start-up. Tried also V1 and V12 and I get the same error.
32bit Libraries are installed (I hope every) as all the dependencies.
I launched the program with gdb, here the backtrace:
[code]Program received signal SIGFPE, Arithmetic exception.
0xee914540 in ?? () from /usr/lib32/libglib-2.0.so.0
(gdb) bt
#0 0xee914540 in ?? () from /usr/lib32/libglib-2.0.so.0
#1 0xee8d7f1f in g_array_sort () from /usr/lib32/libglib-2.0.so.0
#2 0xeecd4684 in ?? () from /usr/lib32/libgio-2.0.so.0
#3 0xeecd65bb in g_file_attribute_matcher_new () from /usr/lib32/libgio-2.0.so.0
#4 0xeed71e82 in ?? () from /usr/lib32/libgio-2.0.so.0
#5 0xeecc874c in g_file_query_info () from /usr/lib32/libgio-2.0.so.0
#6 0xeefb2fa1 in ?? () from /usr/lib32/libgtk-x11-2.0.so.0
#7 0xeefb5e31 in gtk_icon_info_load_icon () from /usr/lib32/libgtk-x11-2.0.so.0
#8 0xeefb5fcd in gtk_icon_theme_load_icon () from /usr/lib32/libgtk-x11-2.0.so.0
#9 0xeefb09e6 in gtk_icon_set_render_icon () from /usr/lib32/libgtk-x11-2.0.so.0
#10 0xef128f02 in gtk_widget_render_icon () from /usr/lib32/libgtk-x11-2.0.so.0
#11 0xeefc7076 in ?? () from /usr/lib32/libgtk-x11-2.0.so.0
#12 0xeefc70a1 in ?? () from /usr/lib32/libgtk-x11-2.0.so.0
#13 0xee9c7df5 in g_cclosure_marshal_VOID__BOXEDv () from /usr/lib32/libgobject-2.0.so.0
#14 0xee9c35f7 in ?? () from /usr/lib32/libgobject-2.0.so.0
#15 0xee9c50ed in ?? () from /usr/lib32/libgobject-2.0.so.0
#16 0xee9de39a in g_signal_emit_valist () from /usr/lib32/libgobject-2.0.so.0
#17 0xee9df33c in g_signal_emit_by_name () from /usr/lib32/libgobject-2.0.so.0
#18 0xef063225 in ?? () from /usr/lib32/libgtk-x11-2.0.so.0
#19 0xef0644ff in ?? () from /usr/lib32/libgtk-x11-2.0.so.0
#20 0xef11fea0 in gtk_widget_size_request () from /usr/lib32/libgtk-x11-2.0.so.0
#21 0xeef21cb3 in ?? () from /usr/lib32/libgtk-x11-2.0.so.0
#22 0xee9c7df5 in g_cclosure_marshal_VOID__BOXEDv () from /usr/lib32/libgobject-2.0.so.0
#23 0xee9c35f7 in ?? () from /usr/lib32/libgobject-2.0.so.0
#24 0xee9c50ed in ?? () from /usr/lib32/libgobject-2.0.so.0
#25 0xee9de39a in g_signal_emit_valist () from /usr/lib32/libgobject-2.0.so.0
#26 0xee9df33c in g_signal_emit_by_name () from /usr/lib32/libgobject-2.0.so.0
#27 0xef063225 in ?? () from /usr/lib32/libgtk-x11-2.0.so.0
#28 0xef0644ff in ?? () from /usr/lib32/libgtk-x11-2.0.so.0
#29 0xef11fea0 in gtk_widget_size_request () from /usr/lib32/libgtk-x11-2.0.so.0
#30 0xeef1672b in ?? () from /usr/lib32/libgtk-x11-2.0.so.0
#31 0xee9c7df5 in g_cclosure_marshal_VOID__BOXEDv () from /usr/lib32/libgobject-2.0.so.0
#32 0xee9c35f7 in ?? () from /usr/lib32/libgobject-2.0.so.0
#33 0xee9c50ed in ?? () from /usr/lib32/libgobject-2.0.so.0
#34 0xee9de39a in g_signal_emit_valist () from /usr/lib32/libgobject-2.0.so.0
#35 0xee9df33c in g_signal_emit_by_name () from /usr/lib32/libgobject-2.0.so.0
#36 0xef063225 in ?? () from /usr/lib32/libgtk-x11-2.0.so.0
#37 0xef0644ff in ?? () from /usr/lib32/libgtk-x11-2.0.so.0
#38 0xef11fea0 in gtk_widget_size_request () from /usr/lib32/libgtk-x11-2.0.so.0
#39 0xeef2a02b in ?? () from /usr/lib32/libgtk-x11-2.0.so.0
#40 0xee9c7df5 in g_cclosure_marshal_VOID__BOXEDv () from /usr/lib32/libgobject-2.0.so.0
#41 0xee9c35f7 in ?? () from /usr/lib32/libgobject-2.0.so.0
#42 0xee9c51b1 in ?? () from /usr/lib32/libgobject-2.0.so.0
#43 0xee9de39a in g_signal_emit_valist () from /usr/lib32/libgobject-2.0.so.0
#44 0xee9df33c in g_signal_emit_by_name () from /usr/lib32/libgobject-2.0.so.0
#45 0xef063225 in ?? () from /usr/lib32/libgtk-x11-2.0.so.0
#46 0xef0644ff in ?? () from /usr/lib32/libgtk-x11-2.0.so.0
#47 0xef11fea0 in gtk_widget_size_request () from /usr/lib32/libgtk-x11-2.0.so.0
#48 0xf3b6f5bd in wxButtonBase::GetDefaultSize() () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_gtk2u_core-2.8.so
#49 0xf3b6f6cb in wxButton::DoGetBestSize() const () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_gtk2u_core-2.8.so
#50 0xf3c30afa in wxWindowBase::GetEffectiveMinSize() const () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_gtk2u_core-2.8.so
#51 0xf3c30b4b in wxWindowBase::SetInitialSize(wxSize const&) () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_gtk2u_core-2.8.so
#52 0xf3b7b232 in wxControl::PostCreation(wxSize const&) () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_gtk2u_core-2.8.so
#53 0xf3b6fa3b in wxButton::Create(wxWindow*, int, wxString const&, wxPoint const&, wxSize const&, long, wxValidator const&, wxString const&) ()
#54 0xf3976314 in wxButtonXmlHandler::DoCreateResource() () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_gtk2u_xrc-2.8.so
#55 0xf39b9f90 in wxXmlResourceHandler::CreateResource(wxXmlNode*, wxObject*, wxObject*) ()
#56 0xf39bc000 in wxXmlResource::CreateResFromNode(wxXmlNode*, wxObject*, wxObject*, wxXmlResourceHandler*) ()
#57 0xf39a1cfb in wxSizerXmlHandler::Handle_sizeritem() () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_gtk2u_xrc-2.8.so
#58 0xf39a2720 in wxSizerXmlHandler::DoCreateResource() () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_gtk2u_xrc-2.8.so
#59 0xf39b9f90 in wxXmlResourceHandler::CreateResource(wxXmlNode*, wxObject*, wxObject*) ()
#60 0xf39bc042 in wxXmlResource::CreateResFromNode(wxXmlNode*, wxObject*, wxObject*, wxXmlResourceHandler*) ()
#61 0xf39bc2bb in wxXmlResourceHandler::CreateChildren(wxObject*, bool) () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_gtk2u_xrc-2.8.so
#62 0xf39a0dcf in wxSizerXmlHandler::Handle_sizer() () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_gtk2u_xrc-2.8.so
#63 0xf39a26f4 in wxSizerXmlHandler::DoCreateResource() () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_gtk2u_xrc-2.8.so
#64 0xf39b9f90 in wxXmlResourceHandler::CreateResource(wxXmlNode*, wxObject*, wxObject*) ()
#65 0xf39bc000 in wxXmlResource::CreateResFromNode(wxXmlNode*, wxObject*, wxObject*, wxXmlResourceHandler*) ()
#66 0xf39a1cfb in wxSizerXmlHandler::Handle_sizeritem() () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_gtk2u_xrc-2.8.so
#67 0xf39a2720 in wxSizerXmlHandler::DoCreateResource() () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_gtk2u_xrc-2.8.so
#68 0xf39b9f90 in wxXmlResourceHandler::CreateResource(wxXmlNode*, wxObject*, wxObject*) ()
#69 0xf39bc042 in wxXmlResource::CreateResFromNode(wxXmlNode*, wxObject*, wxObject*, wxXmlResourceHandler*) ()
#70 0xf39bc2bb in wxXmlResourceHandler::CreateChildren(wxObject*, bool) () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_gtk2u_xrc-2.8.so
#71 0xf39a0dcf in wxSizerXmlHandler::Handle_sizer() () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_gtk2u_xrc-2.8.so
#72 0xf39a26f4 in wxSizerXmlHandler::DoCreateResource() () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_gtk2u_xrc-2.8.so
#73 0xf39b9f90 in wxXmlResourceHandler::CreateResource(wxXmlNode*, wxObject*, wxObject*) ()
#74 0xf39bc000 in wxXmlResource::CreateResFromNode(wxXmlNode*, wxObject*, wxObject*, wxXmlResourceHandler*) ()
#75 0xf39bc2bb in wxXmlResourceHandler::CreateChildren(wxObject*, bool) () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_gtk2u_xrc-2.8.so
#76 0xf39820d0 in wxDialogXmlHandler::DoCreateResource() () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_gtk2u_xrc-2.8.so
#77 0xf39b9f90 in wxXmlResourceHandler::CreateResource(wxXmlNode*, wxObject*, wxObject*) ()
#78 0xf39bc000 in wxXmlResource::CreateResFromNode(wxXmlNode*, wxObject*, wxObject*, wxXmlResourceHandler*) ()
#79 0xf39bca13 in wxXmlResource::LoadDialog(wxDialog*, wxWindow*, wxString const&) () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_gtk2u_xrc-2.8.so
#80 0xeb3d9c95 in lm::DlgUserInfo::DlgUserInfo(wxWindow*) () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libLicenseManager5.so
#81 0xeb3dd85c in lm::LicenseManagerImp::checkLicense(lm::EProduct, lm::EPlatform, short, std::basic_string, std::allocator > const&, void*, short) () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libLicenseManager5.so
#82 0xf6331962 in ca::LicenseManager::checkLicense() () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libcadapp.so
#83 0xf7e5666c in cmd::CmdApp::cmdInit() () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libcommands.so
#84 0x0806d6c8 in wxc::WxcApp::OnInit() ()
#85 0x0806f4e1 in wxAppConsole::CallOnInit() ()
#86 0xf3e2ff10 in wxEntry(int&, wchar_t**) () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_baseu-2.8.so
#87 0xf3e30117 in wxEntry(int&, char**) () from /home/dino/Downloads/BricsCAD-V13.1.9-1-en_US/libwx_baseu-2.8.so
#88 0x0806b73c in main ()
[/code]
Anyone using arch has the same error? did you solve it? (I've also submitted a support request)
(gdb) bt
[/code]
I am glad to announce that the Chakra development team fixed the issues and it is working flawlessly again.
Howdy, Stranger!
