Open Files with Windows Explorer
can I open dwg files in the same bricscad(not open a bricscad new application each time) if it's open with windows explorer ?
Sure.
And if you have the lovely DocTabs app loaded, you will see newly opened dwg.s in the tab control bar.
Thanks a lot0
The SDI (Single Document Interface) variable can also affect this. The command is SDI - set it to OFF to allow all opened drawings to appear in one instance of Bricscad. You can also do this via lisp:[code](setvar "sdi" 0)[/code]0
