Exporting points or block to Excel
Does anyone have a lisp that can export points or blocks to a excel spreadsheet? All I need is a list of X, Y, Z coordinates.
Hi James,
perhaps this will help to get you started. The following function will return a list of 3D coords for the selected object (assuming it meets requirements):
[code];------------------------------------------------------------------------------
; Copyright (C) 2012 CAD Concepts Limited.
; CCL:LISTCOORDS
; This work by CAD Concepts Ltd is licensed under a Creative Commons
; Attribution-ShareAlike 3.0 Unported License. Refer the following link:
; http://creativecommons.org/licenses/by-sa/3.0/nz/deed.en
; For options available to you under this license.
; PURPOSE
; Returns a list of 3D coordinates for a given entity
; Polylines returns a list with a point for each coordinate
; Lightweight Polylines uses the elevation for Z coordinate
; Closed polylines will have the start point appended to the end of the list
; all other objects checks whether a start and end point is available and returns a list of these points if available
; EXAMPLE
; (CCL:LISTCOORDS (car (entsel "\nSelect object (Polyline, Line) to return coords of:\n")))
; Select a 50 x 30 rectangular polyline shape drawn from 0,0
; if CLOSED returns something like
; ((0.0 0.0 0.0) (50.0 0.0 0.0) (50.0 30.0 0.0) (0.0 30.0 0.0) (0.0 0.0 0.0))
; if OPEN returns something like
; ((0.0 0.0 0.0) (50.0 0.0 0.0) (50.0 30.0 0.0) (0.0 30.0 0.0))
; This software is provided "as is". No liability is taken of
; FITNESS FOR ANY PARTICULAR PURPOSE.
(defun CCL:LISTCOORDS (ent / obj objtype objcoords coorList coordtype elevation numcoords num xval yval zval pointlst)
; Using visual lisp. Make sure the visual lisp extensions are available
(vl-load-com) ; this isn't required by BricsCAD
(setq obj (vlax-ename->vla-object ent)) ; convert to vl object
(setq objType (vlax-get-property obj 'ObjectName)) ; find what type of object it is
(cond
; CONDITION 1
; Object is a Lightweight, 2d, or 3d Polyline
; return a list of the coordinates
((or (= objtype "AcDbPolyline") (= objtype "AcDb2dPolyline") (= objtype "AcDb3dPolyline"))
(setq objcoords (vla-get-coordinates obj)) ; retrieve the Coordinates
; (setq objcoords (vlax-get-property obj 'coordinates); Alternative method to retrieve these properties
(setq coordList (vlax-safearray->list (vlax-variant-value objcoords))) ; convert coordinates from an array to a list
(if (= objtype "AcDbPolyline") ; If the object is a Lightweight Polyline
(setq
coordtype 2 ; THEN set number of coordinates to 2
elevation (vlax-get-property obj 'Elevation) ; and find the Polylines Elevation
(setq coordtype 3) ; ELSE set number of coordinates to 3
); end if
(setq numcoords (/ (length CoordList) coordtype)) ; calculate the number off coordinates in the list
;(princ (strcat "\nNumber coords " (itoa numcoords) "\n"))
(setq num 0); zero counter
(repeat numcoords
(setq xval (nth num coordlist)) ; Get the X value
(setq num (1+ num)); Iterate counter to the Y value
(setq yval (nth num coordlist)) ; Get the Y value
(if (= coordtype 2) ; if this is a 2D coordinate list
(setq zval elevation) ; then set the Z to the given elevation
(setq num (1+ num) ; otherwise iterate the counter and get the Z from the coordinate list
zval (nth num coordlist)
(setq pointlst (cons (list xval yval zval) pointlst)) ; THEN add it to our points list
(setq num (1+ num)); Iterate counter to the next X Value
); end Repeat
(setq pointlst (reverse pointlst)) ; reverse our list
(if (= ':VLAX-TRUE (vlax-get-property obj 'Closed)) ; If the polyline is closed
(setq pointlst (append pointlst (list (car pointlst)))) ; Then add the start point to the end of the list
); end if
) ; end CONDITION 1
; CONDITION 2
; For all other objects
; return a list of the start & end point if available
(T
(if (and (vlax-property-available-p obj 'StartPoint)(vlax-property-available-p obj 'EndPoint)) ; check if the object has a start point & end point
(setq pointlst
(mapcar
(function
(lambda (objPoint)
(vlax-safearray->list (vlax-variant-value objPoint)) ; convert the point from an array to a list
(list (vlax-get-property obj 'StartPoint)(vlax-get-property obj 'EndPoint)) ; create a list of the two points
) ;end mapcar
); end if
); end CONDITION 2
); end COND Statement
; return the points list
pointlst
); end CCL:LISTCOORDS[/code]
You could use the above to collect points for Polylines & Lines. Just need to create something to write it out to file, or send straight to excel.
For blocks you can use the rather dated _ATTEXT command. Kinda clunky, but it works.
Regards,Jason Bourhill
Awesome, thanks Jason.0
Lee Mac has a function called PtManager that does just what you are looking for. You may have to tweek it, to get it to run in Bricscad but it is a great utility.
Google LeeMac Programming, he has about 100 utilities on his website fro free.
Bruce0
