Image frame and select
![Randy Long](https://forum.bricsys.com/uploads/userpics/606/nUOGOX5YAXLQA.png)
in Other
Hi all,
I typically insert raster images into my layouts. So, I will usually turn off image frames so they don't print out. But, when I want to select the image, I have to turn imageframes back on. There used to be a keyboard shortcut to select the image with CTRL+A in autocad. I've tried several ways now, but can't figure out if there is an equivalent in Bricscad.
Any ideas?
There is a 'Display but do not plot' option for FRAMES. This setting will override the IMAGEFRAME setting. If you look in the Settings dialog (> Drawing > Underlays) this option seems to be also available for IMAGEFRAME. but I am unable to change IMAGEFRAME through the dialog. And on the command line only ON or OFF are acceptable for IMAGEFRAME.0
Roy,Thanks for the help. That was perfect. I think as long as you know you can change the FRAME or the IMAGEFRAME settings, you should be good to go.Thanks again.0
