Print dialog box not appearing
Hi all,
I cannot print AT ALL. The dialog box won't appear? I have had issues with the printers dropping out but fixed with "net start spooler" on the run coomand and they re-appear.
The Bricscad error however, is not so easy.
FILEDIA variable, perhaps? If set to On FILEDIA should cause Bricscad to use dialog boxes.0
I have noticed that the plot or print dialog does not appear if you use the PLOT command, it does if I use the PRINT command instead. When it comes to dialog boxes, there are three commands that control the way that various dialog boxes run:- ATTDIA: Controls the display of the attribute definition dialog boxes;- CMDDIA: Controls the display of command replated dialogs - ensuring that this is set to 1, or on will control the display of the print/plot dialog;- FILEDIA: Controls the display of file system related dialog boxes;0
Hello Scott, if the print dialog doesn't appear it means there is a problem. We recommend filing a supportrequest about this if you haven't done so already.0
