You can have a block when turning
good afternoon
You can have a block when turning, have a text or an entity that does not rotate with the set?
With the restrictions I can not.
Thank you.
  • Entities included in a block definition are defined in the block's entity coordinate system, so I see no way a constraint could prevent them from rotating with the block.
    However, (text)attributes are not part of the block definition and can be rotated via the attribute editing dialog (invoked by double-clicking on an attribute).
    You may also find some LISP macro that rotates blocks while keeping the angle of attributes unchanged, but I never looked into that.
