How to delete a file from plain Lisp?
I normally use this line to delete a file from Lisp:
(command "shell" (strcat "del " "1run.txt"))
I want to use a specify a drive also, like this:
(command "shell" (strcat "del " "H:/1run.txt"))
But it does not work. The file is not deleted.
I am using Bricscad V6, so I assume that the VL delete function is not usable.
Does anyone know how I can solve this?
Howdy, Stranger!
