Installing Bricscad V12 on a Citrix Xenapp server, how to?
Is there any special issues to take care of when installing Bricscad V12 on a Citrix server ?
When I start Bricscad from a client, I get a lot of errors about drive/foldernames not allowed to access/find.
Is there a guide somewhere to help install Bricscad on the Citrix server?
Hi Svend,
Try searching the knowledge base
http://www.bricsys.com/common/knowledge/topic.jsp?id=248
http://www.bricsys.com/common/knowledge/topic.jsp?id=269
Otherwise try raising a support request.
Regards,Jason Bourhill
Thanks for quick response.
The version described is V8 and V9.
Is there any changes in the behaviour or setting to V12, which I am using?
Is there any news about Bricscad V13 and Xenapp V5?
We have some trouble with V12 and same Citrix. "Cannot create path.....:"
I will try V13 in stead of - therefor if anyone knows what to take care of when installing on the server??
