dxb out
in Other
I am looking for a possibility to 'flatten' a 3d-view into a 2d editable dwg file. When I used to use Autocad there was a possibility to print to a dxb plotter. Does anybody have an idea how to do this in bricscad V11?
Thanks!
Have a look at the flatshot command.0
Excuse me - flatshot was introduced in V12, in V11 you have to use solprof in a layout window.
But don't expect much when it comes to perspective views...0 -
Thanks!
one possibility would be to plot to a HPGL2 plotter into a file (plot to file) after installing the respective driver
for a HP plotter model and then use the following utility to convert to DXF and import to Bricscad V11 or any other version
HPGL to DXF convereter:
http://www.noliturbare.com/convert/plt-to-dxf0
