Lisp - extracting subentities from a block
Hello there,
I'm currently working on a AutoLisp program to extract the DXF-Information (Group code) from sub entities (lines, circls, polylines and so on) contained in an Insert/Block and write it to a file. I did quite well extracting Entities from a drawing but for this issue I only have a rough idea.
variables used:
cntr (Counter)
oSubEnt (old subentity)
nSubEnt (new subentity)
subEntList (list of all subentities)
(setq subEntList(list))
(setq oSubEnt "")
(while (< cntr(sslength [set of all sub-entities]))
(setq nSubEnt (entget(entnext(cdr(car oSubEnt)))))
[add nSubEnt to subEntList]
(setq oSubEnt nSubEnt)
(setq cntr (+ cntr 1))
Practically I need help with everything within the square braces. I developed the basic idea from reading Jeffery P. Sanders tutorial. If it actually told how I could solve this problem I ether overred it or simply didn't understand.
I'd be very thankfull for every kind of help.
Please note my actual mothertongue is german so i ask you to excouse my possible typos and grammar misstakes.
Hi Stefen,
use the following routine to display the DXF codes in the Text Window (F2)
or to write them to a file....you can select any entity
For subentities of Blocks you will have to read the block definition of the INSERT
the command is listDXF
Here is the code
I hope this helps !
[code]
(defun print_elist (elist flag / filenam fp )
(if flag
(progn
(setq filenam (getfiled "TXT Datei erstellen" "" "txt" 1))
(setq fp (open filenam "a"))
(foreach idx elist
(print idx fp)
(close fp)
(progn
(foreach idx elist
(print idx)
(princ)
(defun atr_pop (en / lst AtrList )
(setq AtrList (list "ATR" ))
(while (not (equal (cdr (assoc 0 lst)) "SEQEND"))
(setq en (entnext en)
lst (entget en)
AtrList (append AtrList lst)
(cdr AtrList)
(defun c:listDXF ( / en elist flagFile)
(prompt "Select an Entity :\n")
(setq en (car(entsel))
elist (entget en)
(if (AND (= (cdr (assoc 0 elist)) "INSERT") ; if Block Insert
(= (cdr (assoc 66 elist)) 1) ; if attributes exist
(setq elist (append elist (atr_pop en)))
(setq flagFile (getstring "\nWrite to a file : "))
(if (OR (equal (strcase flagFile) "Y")
(equal (strcase flagFile) "YE")
(equal (strcase flagFile) "YES")
(print_elist elist T)
(print_elist elist nil)
(princ)
[/code]
@ Steven:
[code]; Return value: List of enames.
(defun Block_EnameListNested (blockName / ename ret)
(if (setq ename (tblobjname "block" blockName))
(reverse
(while (setq ename (entnext ename))
(setq ret (cons ename ret))
)[/code]
To manipulate the list look into the Lisp functions foreach, append and cons.
You should be aware that certain group codes in the entget-list (e.g. the ones with enames) make no sense when written to a text file. So you need a way to filter out those group codes.0 -
First of all thank you to the two of you!
@Konstantin:
Your code didn't exactly do what I was looking for (yet it wasallready executable). But it helps me a lot understanding Lisp.... At least I think so!@Roy:
Your code PROPABLY does the Job. All I need to do now is to figure out a way to crochet it into my existing code properly.A little confession: This is my second day of learning Lisp and working with it and I feel like a total noob asking These questions.
Stefen,
i have integrated the code from Roy with minor changes into my code...
So now you get everything from a block...
All the DXF data from the Block Table (Block definition, Nested Entities+ ATTDEF )
and from the Entities Section (Block Insert, Attributes if exist)
You can choose to dump everything to the text screen or write it to a file !
...command listDXF
Here is the code
[code]
(if flag
(progn
(foreach idx elist
(print idx fp)
(close fp)
(progn
(foreach idx elist
(print idx)
(princ)
lst (entget en)
(cdr AtrList)
elist (entget en)
(if (= (cdr (assoc 0 elist)) "INSERT") ; if Block Insert
(setq elist (append (Block_EnameListNested (cdr (assoc 2 elist))) elist ) )
(if (AND (= (cdr (assoc 0 (entget en))) "INSERT") ; if Block Insert
(= (cdr (assoc 66 (entget en))) 1) ; if attributes exist
(princ)
; Return value: List of enames of block nested entities from Block Definition
ret (entget ename)
(if ename
(setq ret (append ret (entget ename) ))
[/code]0 -
A thousand thanks!
Thats exactly what I needed. I'll emedietly beginn to fit your solution into my code.
Thanks Roy and thanks Konstantin!0
