entuty snap markers
in Other
Is it possible to change the icon for entity snap marker ?. I mean the marker on the display, for instance a circle instead of a rectangle for the end of line ?
If you mean size, thickness etc... Type OPTIONS in command line and into searchfield typ "snap marker".0
Thank's.
But what I mean is the shape of the mark. For instance, if I choose to snap to the middle of a line or an arc, I get a triangle mark. Is it possible to change this mark to another figure ?0
