divide o measure
can I do that when you insert a block, the "command divide or measure" I requested the scale of the block?
Hi Antonio,
The option to scale blocks on insertion isn't included with either the _MEASURE or _DIVIDE command. However after running these commands, you could use Quick Select on the _PROPERTIES (CTRL + 1) bar to select the inserted blocks, and then change their scale.
There is a video on Quick Select under the tutorials section of the Bricsys site.
https://www.bricsys.com/en_INTL/bricscad/tutorials/
Regards,Jason Bourhill
Thanks (and sorry for the delay in give them to you)
as you would do that from a command to use lisp?0
