Use a factor for a field?
I want to use a factor for a field.
Example: drawing units represent millimetres, but an area value should be expressed in square metres.
This does not seem possible at the moment. Does anybody know of a work-around?
Hello Roy,
I ran into this problem some time ago. This is an excerpt from the SR:
Question:
2012-06-13 15:55 UTC
I need a field to display the area of hatches in sqm, while the drawing uses centimeters as units.
I read somewhere in the autodesk docs that you could apply a conversion factor to fields, but couldn't find this on V11. Is this possible somehow, in V11 or V12?
2012-06-14 13:39 UTC
to circumvent the broken field dialog, I tried to enter the field code manually - but this did not work, neither in the internal mtext editor, nor in an external one - the input is simply not parsed.
So, before I waste more time on this, the question would rather be: is there a way to insert the field codes (including a conversion factor) and have them evaluated through the LISP API?
Answer:
2012-06-16 09:10 UTC
Indeed, in Autocad can be applied a conversion factor to the fields. For the moment this cannot be done in Bricscad. I will ask about this implementation and I will update you.
2012-06-27 11:06 UTC
We have no short term plans for implement an Additional Format option in Field dialog window.
This has been added as Feature Request and I will keep you updated about it.
The SR is still open...
If you find a way around this, please post back! -
OK, here is a workaround.
- Only works on fields that are unformatted.
- The decimal format is hard-coded.
- There is a strange bug in BC13.1.18 when using (entmod) on a field. If this bug gets fixed in a future version the code will no longer work. -
Perfect - thanks a lot for sharing!
The script runs fine on linux, too. I just replaced the getstrings for precision and factor by getvars (misused DIMALTD and DIMALTF), and that's it for my needs.
Only problem is that I can't seem to get undo to work properly - but I still have to take a closer look.
Do I understand you right that you cannot work on already formatted fields, because it is currently impossible to overwrite the format string via entmod? -
Yes. Somehow you can only add to the existing string. I will try to look into the undo problem. But this may stay tricky.Do I understand you right that you cannot work on already formatted fields, because it is currently impossible to overwrite the format string via entmod? -
Hi Roy,
I think the undo problem is mostly cosmetic:
If you format a field, then regen, then undo until the format string is removed, the now non-existing format gets reapplied with the next regen, and survives even updatefield. But reopening the drawing clears this, so for me, it's not a show stopper.
The entmod glitch is a little more embarassing, but at least, the formatting can be deleted via the gui... -
I have added a solution for the UNDO problem. The function now copies the selected entity, deletes the entity and applies the format string to the new entity. This solution falls into the if-you-can't-make-it-fake-it category, but the result is a 'correct' UNDO-REDO sequence. Of course the fact that a new entity is created can be problematic in cases where the draworder is important.
Howdy, Stranger!
