annotate polylines with cumulative running distances
I need to create cumulative distances (Chainages) along a polyline.
Thanks to Rakesh I can annotate the vertices, but would like to be able to set the distance between annotations.
Example - annotate at Chainage 10, 20, 30, and so on, as well as the vertices.
Is there a simple routine that does this please?
It would be good to have the annotations as simple numeric text.
Thanks
  • 11 years later and I still would like to know the answer to this.
  • Just Google "Chainage autocad lisp" you will find multiple versions for what you want. The various code have different labelling and options re chainage.
