FIND command
In model space the FIND command (used on a selection of entities in case that matters) offers the "Zoom to" option for text entities located using the "Find Next" option.
However this doesn't work on a Layout: the "Zoom to" option is always greyed out. Is this expected behavior? Shouldn't "Zoom to" be available on Layouts or am I missing something?
This is in Version 13.1.18 build id 42484 revision 28842.
Thanks!
-Phil
I think you have stumbled upon a bug, a friend had noted the same issue a few weeks ago; incidentally it works as expected in the latest Linux release...0
Ditto for
Version 13.1.5 build id 40506 revision 27686
Ditto for
