Updateing To a New Release
I'm new to BricsCAD, I've been running V13.1.12, adjusting settings along the way. We are now ready to roll out BC to the rest of the users in the company. My questions is when I update to V13.1.20 what precautions should I take? Will all of the settings that I have adjusted be set back to default setups?
I find even version upgrades about as seamless as you would hope.
The one area I have had to deal with is menus - you are probably asked if you want to keep using the current one or overwrite it.
If you made menu changes (using CUI) you might start on a diversionary course from newer factory menus by retaining your changes there.
I keep those menu items I created, in a MNU file and load it as 'partial CUI' with each minor or major upgrade.
