Mint
Has anyone tried BricsCAD on Mint?
i'm considering moving away from Ubuntu.
  •  I run it on Mint 14 (Cinnamon) and ran in on 12. It loads very easily (.deb version) and I haven't had any problems with it at all.
  • On second thought, I did have some font problems and needed to remove the mscorefonts. I don't know if that problem has been addressed by bricsys or not and I don't know if it was a common problem or not.
  • good to know, thanks
    32 or 64 bit?
  •  32 bit - I loaded it on a 64 bit system but didn't have a chance to run it very long until I changed to 32 for other reasons, so I can't say if it works as it should or not.
  •  in 3D frost :(
  • Bricscad 13.1.19 on Mint 13 64-Bit Long-Term-Support with NVidia driver with latest updates - should be like Mint 14/15.
    I recommend using Mint 13 LTS (supported until 2017).
    http://www.linuxmint.com/oldreleases.php
  •  I am running the 64 bit version on Linux Mint 15. So far so good.
