Copy, Move Rotate (MOCORO)
Does BricsCAD or a third party provide the copy move rotate (MOCORO) command?  I use this one a lot.  It allows you to copy, move and/or rotate on the fly.  Thanks.
  • Hello Beres,
    If you are looking for a third party solution for this and more:
    'Copy and then Rotate' as well as 'Move and then Rotate' are part of our CADPower productivity tool-set.
    See below online documentation:
    http://www.4d-technologies.com/cadpower/manual/build_tools.htm
    You can try the software for 30-days @ www.coordsys.com
    Best Regards
    Rakesh Rao
    http://rakeshrao.typepad.com
  • Try this simple lisp-code. It just copies the selected objects an rotates them.
    Start the function with "CR".
    [code](defun c:CR (/ objects p1 p2)  ;copies an Object and rotates them
      (princ "\nSelect objects to copy and rotate... ")
      (if (setq objects (ssget))
        (if (setq p1 (getpoint "\nbasepoint: "))
          (progn
            (command "_.COPY" objects "" p1 p1)
            (princ "\nsecond point: ")
            (command "_.MOVE" objects "" p1 pause)
            (setq P2 (getvar "LASTPOINT"))
            (princ "\nangle: ")
            (command "_.ROTATE" objects "" P2 "b" "0" pause)
        (princ "\nNo objects selected!")
      (princ)
    )[/code]
    Greeting from Germany
    Stefan Wickel
  • Check out the "Cadalyst" website for free lisp/lsp routines that you can then 'unzip' and bring in to Bricscad using the app load command..............
  • 'Grip Editing' allows to cycle through stretch, move, mirror, rotate and scale commands by hitting the space bar. Read the 'Grips Editing' topic in the BricsCAD Help under User Guide > Modifying Entities.
  •  Beres,
    you might also like to try the _ALIGN command. this can combine Move, Rotate, and Scale in one. Works in 2D, or 3D.
    Have an example of use here for aligning an image.
    CAD Concepts
