Esnap normal to an ellispe
i'm trying to work out reflection angles on an ellipse but esnap doesn't seem to want to snap to it.
is there a trick?
does it not work?
i swear i've done it before.
is there a trick?
does it not work?
Hi Keith,doesn't look like _TANGENT & _PERPENDICULAR object snaps are an option with Ellipses in BricsCAD. Perhaps use PELLIPSE to instead draw polyline Ellipses instead in this case?0
Hi Keith,
it is posible and here it is how...!
Have a look at this Lisp routine over at the "theswamp" :
http://www.theswamp.org/index.php?topic=12813.msg369597#msg369597
How it is done it's left to you as homework by studying the routine ( just joking..)
Here is the code and of cource all credentials and copyright go to the author mentioned in the code
It's one of the most beatiful routines i have seen
[code]
;;; Draw perpendicular line
;;; Alan J. Thompson, 10.15.09
(defun c:LPer (/ #Ent #Read)
(and
(setq #Ent (car (entsel "\nSelect curve: ")))
(vl-position (cdr (assoc 0 (entget #Ent))) '("LWPOLYLINE" "ARC" "LINE" "CIRCLE" "ELLIPSE"))
(while (not (eq 25 (car (setq #Read (grread T 15 0)))))
(princ "\rSpecify point for line: ")
(redraw)
(if (vl-consp (cadr #Read))
(grdraw (vlax-curve-getclosestpointto #Ent (trans (cadr #Read) 1 0) T)
1
) ;_ grdraw
) ;_ if
(if (eq 3 (car #Read))
(entmake (list '(0 . "LINE")
(cons 10 (vlax-curve-getclosestpointto #Ent (trans (cadr #Read) 1 0) T))
(cons 11 (trans (cadr #Read) 1 0))
) ;_ list
) ;_ entmake
) ;_ if
) ;_ while
) ;_ and
(redraw)
(princ)
) ;_ defun
[/code]
Save the code as LPER.lsp
Load the code from the command line typing (load "lper.lsp")
Call the program typing the command Lper
then...
Select curve:
after you draw the perpedicular onto the Ellipse(real ellipse)
you can easily draw the Tangent and any other conceivable direction...
Enjoy the dynamic routine (GRREAD is a beautiful function...)
Here is a screenshot....!!!!
Best Regards
Konstantin0 -
Keith,
i forgot to say that you can also use a routine that i developed to draw the so called frenet frame of any curve like ellipse, bspline etc.
The routine draws a tangent, a normal (perpendicular) and a Bynormal (perpendicular in Z+ direction) lines
at every Point of a selected curve.
Please look for details and description in the following thread :
https://forum.bricsys.com/discussion/18209
at position #10
You can call 2 commands : FrenetF and FrenetFP
: frenetf
Please select the Curve (can be any curve):
Please specify Operation ? (Measure-step/Devide-step) : d
Please input a STEP (any number < path-length = 131.87 : 15
: frenetfp
Select curve:
select point on curve:
You find the Lisp Routine attached below
2D View
3D Views
There are some issues with the proposed code by Alan J. Thompson:
1.
Because the (vlax-curve-getclosestpointto) function is used, sometimes a point on the wrong side of the ellipse is found.
2.
During the grread sequence you cannot use normal esnaps. This is problematic for the other endpoint of the line.0 -
Awesome, I run into this issue at least once a week - I think BricsCAD should implement something like this into their entity snaps...0
I use this.
[code]
(defun c:perpl (/ from_object from_point first_derivative line_angle loop perp_line grread_result end_point str)
(setvar "CMDECHO" 0)
(setq old_osmode (getvar "osmode"))
(if (and (setq from_object (entsel "\nSelect curve at point to start the perpendicular line."))
; select
(setvar "osmode" 0)
(setq from_point (cadr from_object)) ; get the point part
(setq from_object (car from_object)) ; get the entity part
(setq from_point (vlax-curve-getclosestpointto from_object from_point))
; adjust point to be on the entity
(not (vl-catch-all-error-p
(setq first_derivative (vl-catch-all-apply
'vlax-curve-getFirstDeriv
(list from_object (vlax-curve-getParamAtPoint from_object from_point))
) ; get the first derivative
(progn
(entmake (list '(0 . "LINE") (cons 10 from_point) (cons 11 from_point)))
; create initial line
(setq perp_line (entlast) ; store the initial line
line_angle (angle '(0 0 0) first_derivative) ; get the slope
loop T ; loop
; (princ "\nSpecify line length: ")
(while (and (setq grread_result (grread T 12 0)) ; control cursor, no error on ESC, normal crosshairs
(/= (car grread_result) 3) ; 3 = point selected
loop ; loop is active
(cond
((= (car grread_result) 5) ; mouse action
(setq end_point (polar from_point
(if (minusp (sin (- (angle from_point (cadr grread_result)) line_angle)))
(- line_angle (/ pi 2))
(+ line_angle (/ pi 2))
(distance from_point (cadr grread_result))
) ; calculate end point
(entmod (subst (cons 11 (trans end_point 1 0)) (assoc 11 (entget perp_line)) (entget perp_line)))
; modify the line
(setvar "osmode" old_osmode)
(princ)
[/code]0 -
