Alias (*.pgp) not loaded - BricsCAD V13 (Spanish) on Lubuntu LXLE.
BricsCAD don't load any defalut.pgp alias.
I try to load the default settings of "Customize" and also I try to give permissions to the folder "/ home / myuser / Bricsys" and "Bricsys / opt /" (and all subfolders and files), but still does not load.
I include a screenshot clarification.
P.D.: Sorry for my bad english...
Exactly the same problem with BricsCAD V13 (Spanish) on Ubuntu 12.10 (64)0
If the file is the one that shipped with bricscad, you should file a support request.
Something that might be worth trying (especially if the file is a custom one) is to remove all special characters from it and see if it loads then - I remember having some problems with text encoding in support files.0 -
It's correct. I save the /home/MyUser/Bricsys/BricsCAD/V13/es_ES/Support/defalt.pgp file as UTF8 encoding and now BricsCAD loads it. Thank you! =:D0
Thanks
