Any way to import contours into a civil drawing from Google Earth?
Civil3d has a slick new option to import contours into AutoCAD based on a Google Earth image you're looking at. Have any third party publishers come up with a similar trick yet for BricsCAD?
Take a look at MapWorks which will extract elevation points from GE and create contours. Depending on your location better data may be available (such as USGS).0
Please take a look at my recently added application CAD-Earth (www.cad-earth.com)It is designed to import data, images and terrain configurations from Google Earth and to export BricsCAD entities and screenshots to Google Earth.Once the terrain mesh is imported to BricsCAD you can create contour lines, sections and profiles.0
