Linux V.13 - Rectangle has only 4 No. vertices
The Bricscad rectangle tool seems have missing vertices/snaps. There are only corner snaps, whereas Autodesk have corner and mid-point-line snaps so editing the rectangle orthogonally is easy by dragging the midpoint snap.
You probably mean grips instead of vertices/snaps.0
