Hatch edit "not yet supported?"
Bricscad will let you hatch an entity but provides no way to edit your hatches? I find this hard to believe. Is this capability like "right around the corner"? I'm trying to remember how long has hatch edit been in AutoCAD - 8 or 9 years at least?
I generally either recreate the hatch or create a new temporary hatch with the properties I want then property paint from the temporary hatch to hatch to be modified. I don't see a great need for a hatch editor.0
Please see help file also.0
Hallo William,
I have been solving the same problem like you. As a result I have developed an application 'HATCHBOUNDARY', whitch in large part subsitute HEDIT ACad command.
You can find it at Bricsys application store, in 'general tools' section.HatchBoundary_screenshot.gif
