64 bit Bricscad
Is someone more in the know about the 64 bit release explain how this effects its use with third party add-ons? Are the compatible with the 64 bit version, or do we need to wait until the developers write 4 bit add-ons?
Also if I have a BricCAD subscription, or both 64 bit and 32 bit downloads available on my license?
BRX applications need to be recompiled to run under x64 version.
Lisp + COM applications should run without problems (VBA is not yet available in x64).
Many greetings !0 -
And yes, both 32 and 64 bit versions are available on your license.
Best regards,0 -
@Torsten Moses:Lisp + COM applications should run without problems.
.NET based add-ons also appear to run without problems.0
