Doctabs doesn't work on Bricscad Pro v12.2.4 64 bit?!
I just installed Bricscad Pro v12.2.4 64 bit and redownloaded Doctabs v1.0.3.14 and reinstalled it.
It doesn't work! The tab bar doesn't show up at all.
I can have a dozen or more files open at once on two instances of Bricscad on my two monitors.
Doctabs is essential, and should be a core part of Bricscad IMHO.
I understand that 32 bit applications have to be recompiled.
I see that Doslib has been. Thanks!
Anybody have any idea how long it will be?
    Hi, I have uploaded a 64 bit version for you to try. Let me know how it works for you
    www.cadext.com/downloads/DocTabs64_EN.exe
    Cheers : )
  • Great, it works. Thank you!
  • Hey Daniel: You are appreciated.
  • AW.some!
    That was much faster than I'd hoped.
    Marvelous! I simply can't get along without it.
    Thanks!
  • Hello, where you downloaded the Bricscad Pro v12.2.4 64-bit?
    Thanks for the reply.
  • 64bit first available in  V13.2.
    You can DL 32bit Version 12.2.18-1 from download page (under "Old Releases")
  • Daniel- I too, like everyone else here love this add-on.  I just installed Brics 13, do you have an update?  I stayed 32bit,
     because I need VBA.
    Thanks!
  • v 1.0.3.14 (working here on v13 32bit) available for DL in Applications Store / Free Tools.
  • Thanks Robt-
    How did youn get it to install to 13?  When I run the installer it only sees installations of 11 and 12.  My 13 doesn't show
    in the list.
  • Curious. Install here offers Bricscad version options. I simply checked off box for v13.
  • My installer shows version 1.0.3.14.  Same as yours?
    For some reason I am unable to download a new copy from the applications store - nothing happens when I hit the download button.
  • Yup 1.0.3.14. Again curious. I can DL no problem.
    Did you check the "I agree" box on the TOS?
  • Got it- for some reason it wouldn't activate the download earlier, this time it worked, and V13 showed up as an option.
    Thanks for the help!
  • Hi, would you still have DocTabs64_EN.exe for BricsCAD V14 x64 ?
    It's not in freetools anymore!
    Thanks.
    Cheers : )
